fanofai
Apr 01, 2022Guide
Network diagnostics for Orbi mesh wifi system?
Hi, I had asked a few questions earlier on setting up a mesh network and grateful to have received valuable suggestions on this thread. We now have a Mesh network built using RBK50 and RBS50Y devic...
fanofai
Apr 01, 2022Guide
FURRYe38 : The property is actually an condominium community. Hence, the distance between the devices is easily 50ft. I suspect the problem may be due to obstruction from buildings, and hence we are trying to change locations to make it as straightline as practical.
CrimpOn : I was hoping there is a readymade tool. I am considering trying Fing. Else, I'll try ping if that doesn't work. Thanks!
-Sharath
Apr 01, 2022Guru - Experienced User
Are you trying to connect the RBR and RBS around this community or just for a single condo home for 1 user?
