Toinewh
Jul 06, 2020Aspirant
Network error - can't connect orbi correctly
Hello everyone, I started to install the Orbi RBR50 in a new house. And I had everything set up for a perfect configuration. But I realized that the hour wasn't accurate: maybe we're not on 2019 ...
- Jul 07, 2020
Gateway sould be the same as what is set on the modem. Usually 255.255.255.0
Your DNS is incorrect. It should be 192.168.1.1 or you can input other DNS addressses, 1.1.1.1, 9.9.9.9, 8.8.8.8 or your ISP actual DNS addresses as well.
Toinewh
Jul 07, 2020Aspirant
The firmware version is 2.5.1.8
The modem used is a Freebox mini 4K (I’m in France). I set the Orbi router in router mode or AP without any change (on router mode, no internet connection at all. Now, on AP mode, which is the most convenient in a French case I guess, the internet connection passes through the Orbi set up, but the Orbi devices can’t connect itself)
Jul 07, 2020Guru - Experienced User
So the RBS are not connecting to the RBR in AP mode?
Yes if your ISP modem has a built in router already, AP mode would be recommended. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- ToinewhJul 07, 2020AspirantI may be unclear :
RBR and RBS are connected together. WiFi signal is covering the entire house and every device makes benefit of it.
Thus, the Orbi set itself is unable to access internet. Unable to connect to NTP, or firmware update. Orbilogin says ERROR: not connected (this affects only the Orbi set)- FURRYe38Jul 07, 2020Guru - Experienced User
Since your ISP is a router as well, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- ToinewhJul 07, 2020AspirantMy current configuration is the 3rd point you explained. I’ve tried the double NAT and figured out that it wasn’t the best way. So I configured it on AP mode, connected to the ISP router/modem. And here is my problem
