katrinahsu
Dec 23, 2019Follower
network is offline
INTERNET CONNECTION PROBLEMS The wifi shows on the phone but it does not have internet. I had restart modem and waiting more than 5mins. I had tried cable plugged in to internet port and mod...
CrimpOn
Dec 23, 2019Guru - Experienced User
It will help if you specify the model of Orbi and the brand/model number of the internet modem.
You are correct that the yellow (WAN) port on the Orbi should be connected to the single (one) ethernet port on the modem.
Power off both the Orbi and the modem.
Power on the modem and wait for it to get established. (at least two minutes, maybe three)
Power on the Orbi and watch the lights.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
It appears you are using the Orbi "app" to set it up?
