aarondyck
Apr 18, 2019Aspirant
Network issue - some pages won't load
I have had my Orbi for over two years now, without any real problems until now. I recently started to have an issue with some web sites resolving. I scratched my head for some time, until I came acro...
dbr09
Sep 25, 2019Aspirant
Did you every figure it out? I just upgraded to the Spectrum 400/20 service (with Orbi RBK50) and I'm having the same issues. No problem with the previous modem.
Thanks.
- FURRYe38Sep 26, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
dbr09 wrote:Did you every figure it out? I just upgraded to the Spectrum 400/20 service (with Orbi RBK50) and I'm having the same issues. No problem with the previous modem.
Thanks.
- aarondyckSep 26, 2019Aspirant
It turned out to be my DNS server. Try using a different DNS and see what you get.
Ah ha. LOL. Glad you got it figured out.
Enjoy. :smileywink:
