warmwaffles
Aug 01, 2018Aspirant
Network keeps dropping wifi and forcing me to restart
I am on the latest version v2.1.4.16
My network is setup like so
Fiber Modem --> Orbi Router --> Netgear Unmanaged Switch --> Rest of hard wired network machines
This was working pe...
warmwaffles
Going through as we speak and am assigning static ips to the wired devices.
Wish I could tell the orbi to assign any wireless stuff after `10.0.0.20` and all the wired components get the other 20.
I will report back to see if this solves the issue. I am sure you are right with network collision. I just don't understand why that would bring the entire network down, wifi included.
Aug 01, 2018Guru - Experienced User
To clairify, Reservation IPs are set ON the router, this is what i'm suggesting here. Static IP addresses are IP address set ON a client device. The static IP address is also set out side of the default DHCP IP address pool.
I recommend this, changing the default IP address pool to somthing small, If your router is using 10.0.0.#, then set the beginning IP address range to 10.0.0.21 to say 10.0.0.50. This will give you a smaller pool to use for IP address Revervations. You can use static IP addresses on either side of this pool were needed. I set my pool for .100 to .200.
What is the Mfr and model# of you ISP modem/ONT?
- warmwafflesAug 01, 2018Aspirant
Yea I just reserved the IPs on the router itself one at a time. Restarted after the three wired machines were set and then powered everything off.
Modem: 844G-1
Wireless is disabled on it.
ISP is an Electric Co-Op
- FURRYe38Aug 01, 2018Guru - Experienced User
Ok, keep us posted.
Looking up some info on your modem...
Seens that your Modem/ONT has routing built in.
http://www.enkom-active.fi/site/assets/files/1706/844g_854g_gc_etsi.pdf
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.- warmwafflesAug 01, 2018Aspirant
Did factory resets on the satellite and router. I am still encountering this issue. I never had it before and haven't done anything new to the network since I set it up initially around July 13th.
