PeterD2019
Jul 13, 2019Follower
Network map
Original setup map had each satellite (2) connecting to primary. After rebooting map shows one satellite connected to primary and the second connected to the first satellite. Which is optimum?
Jul 13, 2019Guru - Experienced User
Up to you and how you have the satellites placed. If in a star arrangement, then Daisy chain needs to be disabled. If out iin a line from the RBR, Daisy Chain can be used letting the RBS piggy back on each other.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
