PeterD2019
Jul 13, 2019Follower
Network map
Original setup map had each satellite (2) connecting to primary. After rebooting map shows one satellite connected to primary and the second connected to the first satellite. Which is optimum?
CrimpOn
Jul 14, 2019Guru - Experienced User
PeterD2019 wrote:Original setup map had each satellite (2) connecting to primary. After rebooting map shows one satellite connected to primary and the second connected to the first satellite. Which is optimum?
If both satellites connect directly to the router, then one satellite is not acting as a "relay" for the other, and thus using more radio and processing time for the relay. On the other hand, if the signal strength from the router directly to the second satellite is very low, then the bandwidth to that satellite will be less. Can you please explain the sequence of "rebooting"? i.e. were all devices powered off and back on simultaneously? Or, was the router powered on first, and then the satellites?
