dzibel's avatar
dzibel
Network Map
I have an orbi router and two satelites. Previously, when I looked at the map - both satellites were connected to the router. Now, they appear in a straight line - i.e., routher --> satellite --> satellite.
Is this about just positioning within my house? Or is there something else going on?
  • Which orbi system do you have?
    Usually it indicates that they're setting up in a daisy chain configuration and not star.
    Star: satellites<------router------->satellite
    daisy: router------->satellite------>satellite
    • dzibel's avatar
      dzibel
      I have the RBR50. And that is exactly right - it was in the star before, and now daisy. It is entirely wireless from router to satellite.
      I assume the star is better? Or does it not matter? Is this a positioning issue, or is there a setting somewhere that I'm missing?
      THANKS.
