Fjones's avatar
Fjones
Follower
Sep 17, 2020
Network password
The network password on the product keeps sayings it’s incorrect
  • plemans's avatar
    The wifi password?
    the password to log into the gui?
    Which password?
    If you can't get on the wifi, simply hardwire into the device and access it. You'll be able to see what the ssid and password are from there.
    Reset the product and try again
