RonKirkpatrick
Sep 07, 2017Aspirant
Network resets
For my own reasons I have my RBR50 configured to run on the network range of 192.168.100.x. Twice now the network range has been reset to 192.168.1.x with a message about the reason being the old rang...
TheEther
Sep 08, 2017Guru
Your modem may be using 192.168.100.x.
- RonKirkpatrickSep 08, 2017AspirantUh, the modem is on the 71.63.x.x side of the router. I would be very much surprised that a modem on the public side of the router would be using a non-routable ip address.
- st_shawSep 08, 2017Master
RonKirkpatrick wrote:
Uh, the modem is on the 71.63.x.x side of the router. I would be very much surprised that a modem on the public side of the router would be using a non-routable ip address.Be surprised then. For example, all the CenturyLink modems have a non-routable IP address assigned to their switched ports (192.168.0.1) which can used to access the modem when the modem is in bridged mode. Any device (such as Orbi) plugged into the modem will get a WAN IP via DHCP.
- RonKirkpatrickSep 08, 2017AspirantBoth devices, Century Link modem and Orbi, should be doing Network Address Translation. Neither device should be putting 192.168.x.x addresses on the public network. The only ports on my Arris TM722 cable modem are 1 Power, 1 Coax, 1 Ethernet (plugged into the Orbi) and 2 Telephone.
