RonKirkpatrick
Sep 07, 2017Aspirant
Network resets
For my own reasons I have my RBR50 configured to run on the network range of 192.168.100.x. Twice now the network range has been reset to 192.168.1.x with a message about the reason being the old rang...
RonKirkpatrick
Sep 08, 2017Aspirant
Both devices, Century Link modem and Orbi, should be doing Network Address Translation. Neither device should be putting 192.168.x.x addresses on the public network. The only ports on my Arris TM722 cable modem are 1 Power, 1 Coax, 1 Ethernet (plugged into the Orbi) and 2 Telephone.
TheEther
Sep 08, 2017Guru
Is the Century Link device a pure modem or a modem/router? Because if it's performing NAT, that implies it handles traffic with private IP addresses and must itself have a private IP address.
But that's orthogonal to the point that st_shaw and I have been trying to make. Even if a device doesn't perform NAT, which would be the case with a pure modem, it can still have a private IP address. The private address is a predictable address that makes it easier to log into the device.
