RonKirkpatrick
Sep 07, 2017Aspirant
Network resets
For my own reasons I have my RBR50 configured to run on the network range of 192.168.100.x. Twice now the network range has been reset to 192.168.1.x with a message about the reason being the old rang...
RonKirkpatrick
Sep 08, 2017Aspirant
Both devices, Century Link modem and Orbi, should be doing Network Address Translation. Neither device should be putting 192.168.x.x addresses on the public network. The only ports on my Arris TM722 cable modem are 1 Power, 1 Coax, 1 Ethernet (plugged into the Orbi) and 2 Telephone.
st_shaw
Sep 08, 2017Master
There are several issues here:
1. Orbi is programmed to automatically change its LAN address range if it detects a conflict on the WAN side.
2. You seem to be operating under the assumption that a network device can have only one IP address. That's not true. An Ethernet port or a switch can have multiple addresses, and they can be on different ranges, including routable and private ranges. TheEther was hypothesizing that your modem was using an address that conflicted with your Orbi LAN. This is a feasible hypothesis.
3. If your network is configured properly you should only have one NAT device. Your comments about both devices doing NAT seem to indicate you might have two NAT devices on your network. That could contribute to your issue.
You should either 1) run Orbi in AP mode, or 2) run Orbi in router mode and run your modem in bridged mode.
If you can describe how things are setup currently, and what your reasons are for using a particular LAN range behind Orbi, that information might help find a solution.
- RonKirkpatrickSep 08, 2017AspirantI have no knowledge of how my ISP has configured the Cable Modem. I was offered the ISP's WiFi, but I prefer to run my own WiFi Router. I don't like to be limited to what the ISP says I should do. If you think the Cable Modem also has a 192.168.100.x address, I can configure to a different range. I picked this one at random. I don't like "default" network configurations and have a tendency to change things to make it harder to "someone" to break into my network or spoof me into thinking they know about my network. (How many have pressed the "Windows Tech Support" folks for at least the IP address of your computer and been told that it's 192.168.0.1?) For this reason, I change as many things as I can to make my system "non-default".
- st_shawSep 08, 2017Master
Yes, change your address range to something other than 192.168.100.0 and you should be good.
Search the below webpage for "192.168.100" and you will find discussions of Arris modems handing out DHCP addresses in the 192.168.100.X range. What you are seeing may indicate intermittent issues with your cable service. (Or power outages, or you pulled the plug, etc.)
https://news.ycombinator.com/item?id=10596667
From the above link: "When the modem can't access the cable infrastructure, it turns itself into a DHCP server and hands out IP addresses in the range 192.168.100.xx. This is useful for people at home whose configurations are such that their home networks won't work properly without some sort of DHCP server provided by the ISP."
- RonKirkpatrickSep 10, 2017Aspirantwell, I've moved to a different range. Time will tell if that fixes the problem.
