NGNewbie
Nov 25, 2020Star
Network security question
Hi, Something called "C2 Development" keeps popping up under my Network connections and even though I turn it off on the ORBI App next day a couple new connections with the same name pop up. I do...
Nov 25, 2020Guru - Experienced User
You might post about this over in the Orbi app forum.
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Do you have Armor or Circle enabled? Try disabling those if you do.
Good Luck.
- NGNewbieNov 25, 2020Star
Thank you very much. Yes, I do have Armor enabled but why would shutting this off resolve the issue? Any idea of what this may be?
- FURRYe38Nov 25, 2020Guru - Experienced User
Seen odd issues and posters with problems seen with Armor. Something to post about in the Armor forum as well to see if there is any additonal information:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
