NGNewbie
Nov 25, 2020Star
Network security question
Hi, Something called "C2 Development" keeps popping up under my Network connections and even though I turn it off on the ORBI App next day a couple new connections with the same name pop up. I do...
NGNewbie
Nov 26, 2020Star
Found it. It seems that this C2 Development, Inc is a part of a US manufacturer that builds the aquarium lights that I use and are WiFi controllable. It must be related to some kind of Update though given I have had them for a number of years and only recently this started to happen.
Nov 26, 2020Guru - Experienced User
Something to post about in the Armor forum and let them know about this...maybe they can add this device to the safe or white list for Armor.
