icarusbon
Sep 03, 2021Aspirant
Network setting when using Netgear M1 & LB2120 & Orbi RBK40 at the same time
I am living in a rural area which landline is not available. I had M1/M2 with Orbi RBR40 but that was not too stable as M1/M2 sometimes would be too "hot" and stop responding. The downtime is so...
icarusbon
Sep 10, 2021Aspirant
Thanks for your suggestion. Glad that DMZ function might help to let Orbi take up the router role.
I searched from the internet and found there are security issues to the router if I use DMZ with the modem. Is Orbi able to set up a firewall to prevent this happening?
Thanks again~
Thanks again~
Sep 11, 2021Guru - Experienced User
ALL Orbi RBK systems have built in Firewalls.
- icarusbonSep 13, 2021Aspirant
Thanks~ So I can treat my LB2120 as a "modem" though it is in a router mode, as LB2120 would bypass all the data through. And the only difference is that the IP address of Orbi router is re-assigned as practically it's a device under LB2120.
