mith_it
May 27, 2018Luminary
Network topology configuration
I just installed the RBK53. I’m trying to cover 3 floors, the router is on the bottom floor, 1 satellite is on second and the other satellite on the third. All satellites at setup time glowed blue. My...
st_shaw
May 28, 2018Master
Unfortunately, you cannot force one satellite to connect through another.
Be sure you have Daisy-chain Topology enabled in the router GUI under: Advanced, Advanced Setup, Wireless Settings. This is required for the feature to work.
