Rangela
Nov 04, 2019Aspirant
Network worked fine then "Connected with problems"
I have an Orbi RB40 with 2 satellites. We have Firesticks on all of the TV's, which we stream our Playstation Vue service. It has worked fine until this weekend when my daughters TV said Home Was ...
Nov 04, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Rangela wrote:I have an Orbi RB40 with 2 satellites. We have Firesticks on all of the TV's, which we stream our Playstation Vue service. It has worked fine until this weekend when my daughters TV said Home Was Unavailable and Connected With Problems. I tried resetting the firestick attached and it did no good. I took my son's working firestick and swapped with it to see if it was firestick related. It no longer will connect to the internet. Our other 3 TV's were working fine but i rebooted the modem and Orbi router, to see if I could restablish protocols. This kicked out my living room TV and it now says the same. I still have 2 working TV's/firesticks but 3 are out of commission. Any ideas on why this might have happened and how I can fix?
