ginmint63
Nov 16, 2021Aspirant
Networked Copier - Scanner -Orbi Install Not working
We installed the Orbi system and our networked copier functions through ethernet, yet the scanner portion doesn't send to our programmed email addresses (error messages). Copier company says it's a ...
- Nov 28, 2021
It turns out the scanner portion of our copier needed a different IP address to be used with the Orbi system. The Tech from Copier Company didn't know this, we figured it out with your input, the manual and a smart young IT person. Thanks for your help!
CrimpOn
Nov 16, 2021Guru - Experienced User
would help to have a link to that post from 2018.
also, brand and model of copier/scanner
Almost certainly not a "Netgear issue."
- ginmint63Nov 16, 2021Aspirant
Kyocera TASKalfa4052ci
- CrimpOnNov 16, 2021Guru - Experienced User
Thanks for the information. Sad to see that the problem was never resolved in 2018.
Is this the correct User Manual?
Emailing scanned documents seems to be on page 5-25
Is the email system being used internal, or one of the common internet services (Gmail, Yahoo, AOL, etc.)?
Can you attach the email setup being used (X out any passwords or user names)
and the error message that appears?
Our IT guy is coming tomorrow. In the meantime, I'm attaching the error message as it may be the IP address for the scanner. Copier Co said it wasn't their deal.
