ginmint63
Nov 16, 2021Aspirant
Networked Copier - Scanner -Orbi Install Not working
We installed the Orbi system and our networked copier functions through ethernet, yet the scanner portion doesn't send to our programmed email addresses (error messages). Copier company says it's a ...
- Nov 28, 2021
It turns out the scanner portion of our copier needed a different IP address to be used with the Orbi system. The Tech from Copier Company didn't know this, we figured it out with your input, the manual and a smart young IT person. Thanks for your help!
ginmint63
Kyocera TASKalfa4052ci
CrimpOn
Nov 16, 2021Guru - Experienced User
Thanks for the information. Sad to see that the problem was never resolved in 2018.
Is this the correct User Manual?
Emailing scanned documents seems to be on page 5-25
Is the email system being used internal, or one of the common internet services (Gmail, Yahoo, AOL, etc.)?
Can you attach the email setup being used (X out any passwords or user names)
and the error message that appears?
- ginmint63Nov 16, 2021Aspirant
Our IT guy is coming tomorrow. In the meantime, I'm attaching the error message as it may be the IP address for the scanner. Copier Co said it wasn't their deal.
- CrimpOnNov 16, 2021Guru - Experienced User
Alas,one of the frustrating aspects of Netgear's forum software is that images placed "in-line" using the Photos icon are not visible to others until approved by a forum moderator. (and there are not many moderators for entire Netgear community). Images "attached" using the Browse button in the lower left are available immediately.
- ginmint63Nov 28, 2021Aspirant
- Mikey94025Nov 20, 2021Hero
CrimpOn wrote:Is the email system being used internal, or one of the common internet services (Gmail, Yahoo, AOL, etc.)?
Agree, this is probably some email/SMTP configuration issue so we need to see the email settings configuration (without passwords). However I don't see anything obvious that would change with the router switch.
In the user manual the email settings are on pages 2-67 and 2-68. There is even a Connection Test button that the OP can try. I'm interested in the OP's printer settings for:
- SMTP Server Name
- Domain Restriction
- Sender Address
Also, what was the old router model? Maybe it had some forwarding setup for the printer's email sending function?
