jtaylor67
Oct 02, 2018Tutor
networked scanner can't scan to email after Orbi install
I have a network scanner that can scan to email. Since I installed my new Orbi router the scanner can't send to email anymore. The error log shows it can no longer find the SMTP server. The Orbi s...
Oct 02, 2018Guru - Experienced User
What FW is currently loaded?
How is the scanner connected to the Orbi? At the satellite or base router?
Has the scanner been reset and set up from scratch with it's networking?
- jtaylor67Oct 04, 2018Tutor
Sorry for the delay.
Firmware is 2.1.4.16.
modem is technicolor, model DPC3216 through Spectrum
scanner is connected to the Orbi directly with an Ethernet cable. Not connected to the satellite.
We have reset all the scanner IP information, including allowing it to pull DHCP info from the Orbi with the same results. Weird thing is that the crazy thing starts working when I put the old router back in place. I don't see anything in the Orbi setup that would cause this.
- FURRYe38Oct 04, 2018Guru - Experienced User
What IP address pool string are you using on the Orbi ruoter? 192.168.1.###? What is the old router using for it's IP address pool string?
Both the Orbi and the old router are both using 192.168.1.xxx IP scheme. Orbi gives a primary DNS of 192.168.1.1 (Orbi) but no secondary. We programmed secondary of 8.8.8.8 to make sure there is DNS resolution to the outside world for it to send email.
