Dd852
Apr 17, 2019Luminary
networking question - bridge vs. new network
I have an Orbi 50 and satellite; I use my ISPs router as the link to its fibre. In the past, I always used the Orbi in Bridge mode. Today, I had to do a pin reset to factory settings as there was a b...
Dd852
Apr 18, 2019Luminary
Thanks - I had been using #3 for about a year... and all was fine until this last pin/factory reset of the orbi and at that point it simply wouldn’t pass through any more. Anyway - i’ve Solved by simply junking the zte and using the orbi as router. All i lose is the ability to have a phone handset connected ... but voip will be fine.
Apr 18, 2019Guru - Experienced User
Yes after a reset you would loose AP mode after the reset as the RBR would default back to router mode.
Yes, if you can disable the modems router and use the Orbi as the router, then you'll be fine.
