Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
defjaf
Feb 03, 2021Tutor
Is this update US-only (as was the last in the 2.7 series)?
- alokeprasadFeb 03, 2021Mentor
defjaf wrote:Is this update US-only (as was the last in the 2.7 series)?
Doesn't say so anywhere.
- FURRYe38Feb 03, 2021Guru - Experienced User
I would not assume that v104 isn't for all regions, this version still follows the v2.7 version line thus may still be considered a continuation fix from the v2.7 line and thus maybe a security fix for what may have been missing in v102 which I is still a US region only version.
This article applies to:
