Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
Ha_Ku_Na
Feb 08, 2021Luminary
Ha_Ku_Na wrote:I upgraded from 2.5.1.16 to 2.7.2.104 yesterday. So far no issues.
In the past I tried several versions after 2.5.1.6 and had issues with all of them within a short time after upgrade.
...- using "VPN Service"
- using "LAN Address reservation" (bind MAC to a fix IP address)
Just to have you updated. After nearly 5 days on 2.7.2.104 -> NO issues at all !
Looks like I do not have to look for (mesh) alternatives (non Netgear).
Feb 08, 2021Guru - Experienced User
Be sure to make a new back up configuration to file for safe keeping.
Enjoy. :smileywink:
Ha_Ku_Na wrote:Ha_Ku_Na wrote:I upgraded from 2.5.1.16 to 2.7.2.104 yesterday. So far no issues.
