Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
arunprasanth
Feb 08, 2021Tutor
I bought the router and it came with FW version v.2.0.0.74. The router / APP is not detecting any updates as available in web interface. Its been just a day with the mesh setup. So far its ok. Is there anything I am missing out without the latest updates. I read somewhere in the forum that we have to go through sequentially for the updates which seems to be a lot and time consuming. If I try updating directly to the latest version, will it fail due to some file size limit or so?
- FURRYe38Feb 08, 2021Guru - Experienced User
You should be able use v2.2.1.212 on the RBS first then on the RBR. I would then try v2.3.5.30 on the RBS then RBR lastly.
Then you should be able to go to v104 on the RBS first then on the RBR lastly.
You'll need to use a wired PC or laptop and web browser. IE11, Edge or Firefox.
Download the FW files here before starting:
https://www.netgear.com/support/product/RBK50.aspx#download
You can connect to the RBSs web page and send the FW files directly to the RBS.
arunprasanth wrote:I bought the router and it came with FW version v.2.0.0.74. The router / APP is not detecting any updates as available in web interface. Its been just a day with the mesh setup. So far its ok. Is there anything I am missing out without the latest updates. I read somewhere in the forum that we have to go through sequentially for the updates which seems to be a lot and time consuming. If I try updating directly to the latest version, will it fail due to some file size limit or so?
- vajimFeb 09, 2021Master
FURRYe38 wrote:You should be able use v2.2.1.212 on the RBS first then on the RBR. I would then try v2.3.5.30 on the RBS then RBR lastly.
Posts like this advising people to upgrade firmware should be viewed with caution. Lots of firmware problems reported here every day
- TedNemoFeb 09, 2021Tutor
Hi All:
Since my RBR50 router has been definitively bricked by the firmware update, I've been reduced to buying a replacement, which has arrived. I'm going to install it later and, I hope. But if presented with the option to update firmware, can you tell me what the latest safe firmware version is. I'm obviously not going to repeat the experiment and attempt the latest firmware.
Thanks very much
- arunprasanthFeb 11, 2021Tutor
Thnx, All I did was update the RBS to v2.2.1.212, and then the RBR to v2.2.1.212. Then both automatically went upto 2.5.1.16 in the same order without asking my permission. Now there's a prompt that latest FW is available for update.
- FURRYe38Feb 11, 2021Guru - Experienced User
The prompt is just letting you know FW is available, it's up to you to update to it or not for this version. IF you do, just select the Update ALL. After the FW is applied, Power OFF the RBS/RBR after updating for 30 seconds then back on.
arunprasanth wrote:Thnx, All I did was update the RBS to v2.2.1.212, and then the RBR to v2.2.1.212. Then both automatically went upto 2.5.1.16 in the same order without asking my permission. Now there's a prompt that latest FW is available for update.
