Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
arunprasanth
Feb 11, 2021Tutor
Thnx, All I did was update the RBS to v2.2.1.212, and then the RBR to v2.2.1.212. Then both automatically went upto 2.5.1.16 in the same order without asking my permission. Now there's a prompt that latest FW is available for update.
Feb 11, 2021Guru - Experienced User
The prompt is just letting you know FW is available, it's up to you to update to it or not for this version. IF you do, just select the Update ALL. After the FW is applied, Power OFF the RBS/RBR after updating for 30 seconds then back on.
arunprasanth wrote:Thnx, All I did was update the RBS to v2.2.1.212, and then the RBR to v2.2.1.212. Then both automatically went upto 2.5.1.16 in the same order without asking my permission. Now there's a prompt that latest FW is available for update.
