Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
Riehmc
Feb 14, 2021Aspirant
Just be aware that if you have a RBR50 and upgrade to 2.7.2.104 then you will lose the parental control feature for Circle.
I rolled back to 2.6.1.40 in order to enable the circle feature and setup the phone app. But then updating back to 2.7.2.104 it disappears again and the phone won't be able to find the circle. I had to rollback again to 2.6.1.40 and enable the feature yet again to restore the circle functionality. Looks like the newest firmware forgot to include it?
- FURRYe38Feb 14, 2021Guru - Experienced User
I think you have to apply v102 first:
https://kb.netgear.com/000062852/How-do-I-upgrade-from-Circle-to-NETGEAR-Smart-Parental-Controls
Then v104.
How I was able to maintain PC throught out each version.
- vajimFeb 14, 2021Master
FURRYe38 wrote:I think you have to apply v102 first:
Then v104.
that would be the truth
- RiehmcFeb 14, 2021AspirantSo I wasted another hour and went back to version 102 and it still didn’t work so then I took it to 104 and still doesnt work. It looks like you’re telling me to use 104 but use Netgear’s parental controls instead of the circle which hopefully has gotten better because in the past their controls were a waste of time and effort
