Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
vajim
Feb 14, 2021Master
FURRYe38 wrote:I think you have to apply v102 first:
https://kb.netgear.com/000062852/How-do-I-upgrade-from-Circle-to-NETGEAR-Smart-Parental-Controls
Then v104.
How I was able to maintain PC throught out each version.
Looks like the newest firmware forgot to include it?
that would be the truth
Aggie88
Feb 14, 2021Apprentice
I upgraded directly from 2.5.2.4 to 2.7.2.104 via the web interface three days ago and I still have Circle and all its functionality.
- txdegawaApr 25, 2021Tutor
I have same issue. When I reset the RBR50 to factory, it was workinng fine for while then start doing "Please Wait A Moment...." Any browser evern reset histories and other cache. Using brand new laptop never get on to internet. When I use iPhone app to accss I can see all my sattelites but information in the app is wrong. No device founds. I am just stuck this screen. I have already three time factory reset. and rebuild my orbi. I just cannot change any information unless factory reset. the internet is working fine all the time. Please advise what am I doing wrong?
- FURRYe38Apr 25, 2021Guru - Experienced User
What are you doing when this message "Please Wait A Moment...." comes up?
What devices are you using when this happens?
Are your devcies wired or wireless?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
txdegawa wrote:I have same issue. When I reset the RBR50 to factory, it was workinng fine for while then start doing "Please Wait A Moment...." Any browser evern reset histories and other cache. Using brand new laptop never get on to internet. When I use iPhone app to accss I can see all my sattelites but information in the app is wrong. No device founds. I am just stuck this screen. I have already three time factory reset. and rebuild my orbi. I just cannot change any information unless factory reset. the internet is working fine all the time. Please advise what am I doing wrong?
