Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
DeanB1452
Feb 14, 2021Apprentice
I don’t know how, but I’m on 104 and still have and continue to use Circle 1st Gen, without any issues. I’ve been through all the progressive updates, many reboots and some factory resets. Never subscribed to Circle or Netgear’s Parental Control either. I’m able to use the app and it switches over to Circle 1st gen app where I can control my kids’ devices.
Aggie88
Your answer makes me think about what I said. I am on Circle version 1 and that hasn't been affected for me. Sorry if I caused any confusion.
- RJW84Feb 18, 2021Aspirant
First post on here since looking to throw my RBR50/RBS50 setup in the bin...
Have just updated to V2.7.2.104 and now my system is dropping connection every 5 minutes and unuseable for work. I'm currently tethering off my phone.
The system was perfect up until this update.Can I roll back to the previous software?
Cheers.
- vajimFeb 19, 2021Master
RJW84 wrote:First post on here since looking to throw my RBR50/RBS50 setup in the bin...
Cheers.
any progress?
- RJW84Feb 19, 2021Aspirant
I've done a clean install and still having a few niggles but definitely better than it was.
The RDS50 in the shed (10m away from RBR50) was having the most issues, and only picking up the 2.4ghz feed, but after lots of swearing at it and a couple of resets, seems to be holding a strong 5ghz connection now.
- dwmacFeb 25, 2021Aspirant
Hello, I had the same issues after the "auto-update" to the latest firmware, constant drops. I did the manual rollback to V2.6.1.40 and everything is stable again.
Worth noting...I had to telnet into both the router and the satellite and disable the auto check and and auto upgrade to prevent it from upgrading again right away. Frustrating but all is well now.
The router and satellite had different firmware files so make sure you download both and rollback the satellite first.
Disable update in satellite then router
Rollback satellite
Rollback router
Link to post for directions on telenet and disabling update features: link
- vajimFeb 25, 2021Master
dwmac wrote:Hello, I had the same issues after the "auto-update" to the latest firmware, constant drops. I did the manual rollback to V2.6.1.40 and everything is stable again.
Rollback satellite
Rollback router
Can you provide a bit more info on what you mean when you say ""auto-update"?
Thanks
