Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
jvetro
Feb 18, 2021Tutor
Good day, does this firmware version resolve the issue with ethernet backhaul or is Firmware V2.5.1.16 still the latest to support this?
My Setup : Hitron ISP Router (Wifi Disabled) (1Gb/ 50Mb) > RBR50 (V2.5.1.16) > RBS50 (V2.5.1.16) (All connected through Ethernet Backhaul)
Feb 18, 2021Guru - Experienced User
Only item you'll see is this with v104:
jvetro wrote:Good day, does this firmware version resolve the issue with ethernet backhaul or is Firmware V2.5.1.16 still the latest to support this?
