Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
Feb 23, 2021Guru - Experienced User
It's recommended to power OFF the ISP modem and entire Orbi system for 1 minute after a FW update, then back on with the modem first, then RBR, then RBS...
ktula
Feb 23, 2021Apprentice
FURRYe38 wrote:It's recommended to power OFF the ISP modem and entire Orbi system for 1 minute after a FW update, then back on with the modem first, then RBR, then RBS...
The satellite most likely had a bad firmware upgrade. No amount of power cycling could resolve the issue. Eventually, i did a factory reset on the satellite. It didn't work after the first factory reset so i repeated it the second time (i put the reset button with a pin while the satellite is powered off for 7 seconds, and just to make sure, i also did that for 7 seconds while it's powered on). The second factory reset appeared to have worked.
- FURRYe38Feb 23, 2021Guru - Experienced User
Sometimes a reset is needed. I recommend 15 seconds press to reset.
Glad you got it working.
