Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
whenasked
Mar 10, 2021Aspirant
I have a RBR50, RBS50 on Router Firmware Version V2.7.2.104.
I also have RBS40V on Firmware Version: V2.6.2.4_1.0.1.
When devices connect to 2.4Ghz on RBS40V, devices stop working. When I switch off RBS40V, and when those devices connect to router or to the other satellite, those 2.4Ghz start working again.
Thanks
vajim
Mar 10, 2021Master
Thanks
was everything working after to V2.7.2.104?
