Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
whenasked
Mar 10, 2021Aspirant
I have a RBR50, RBS50 on Router Firmware Version V2.7.2.104.
I also have RBS40V on Firmware Version: V2.6.2.4_1.0.1.
When devices connect to 2.4Ghz on RBS40V, devices stop working. When I switch off RBS40V, and when those devices connect to router or to the other satellite, those 2.4Ghz start working again.
Thanks
Mar 10, 2021Guru - Experienced User
I would post about this over in the Orbi with Voice for the RBS40v:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Thank you.
whenasked wrote:I have a RBR50, RBS50 on Router Firmware Version V2.7.2.104.
Thanks
