Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
smartt
Mar 19, 2021Aspirant
So, you're basically saying you're smart enough to know what firmware is but not smart enough to not auto-update and let other people test it? Sounds about right.
dwmac
I couldn’t care less what other people do or test. The point of the community is to discuss experiences, issues, workarounds, and solutions. This was my experience and workaround. If it helps someone else then fine. Did you have anything to offer or just come here to run your mouth?
