Feb 02, 2021Guru - Experienced User
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes: Fixes security issues This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Downloa...
- Feb 03, 2021I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
dwmac
Mar 20, 2021Aspirant
This is exactly the behavior I was seeing from RBR50 and RBS50. However, even after I did the firmware rollback to the previous firmware version I started experiencing the same issues again. It was fine for a about a week or 2 and then I started seeing the same symptoms that you described all over again. Orbi reported link to internet was down but all wired devices were working fine and had Internet access. All wireless devices were connected to wifi but no Internet access.
What I finally did this past week was to go ahead and upgrade to the latest firmware again and then I did a facorty reset on the router and satellite and started from scratch with a new install/setup. After the reset, most of the settings were reverted back to default like my IP addresses but not everything, including the firmware, it is still the latest. All of my devices were also still listed in the attached devices by the names I had given them before the reset. So apparently the factroy reset did not completely wipe everything out as one would think it would ( I did it multiple times per Netgear instructions ).
Anyway, it has been 5 days now and zero issues. Hopefully, it doesn't start happening again.
Mar 20, 2021Guru - Experienced User
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
I preref to use the ERASE function on the RBR to to a factory reset. Factory resets will not change the FW version. Only user settings are cleared.
dwmac wrote:This is exactly the behavior I was seeing from RBR50 and RBS50. However, even after I did the firmware rollback to the previous firmware version I started experiencing the same issues again. It was fine for a about a week or 2 and then I started seeing the same symptoms that you described all over again. Orbi reported link to internet was down but all wired devices were working fine and had Internet access. All wireless devices were connected to wifi but no Internet access.
- lmellingMar 20, 2021Guide
omeone suggested turning off automatticaly adjust for daylight savings time, seems for work, no reboots for 2 days
See advanced/administration/NTP Settings I also set NTP Server to time.nist.gov, not sure that helped or not.Good luck,
Hey Netgear, how about releasing a patch or updateing the release notes? Your customers are losing faith!- FURRYe38Mar 20, 2021Guru - Experienced User
Just curiuos, do you use Traffic Meter?
lmelling wrote:omeone suggested turning off automatticaly adjust for daylight savings time, seems for work, no reboots for 2 days
Hey Netgear, how about releasing a patch or updateing the release notes? Your customers are losing faith!- lmellingMar 20, 2021Guide
It may hae been on previously, not sure, but it is off at this time.
