FURRYe38's avatar
New - Orbi RBR50 Router Firmware Version V2.7.2.104 Released
Security Fixes:
  • Fixes security issues
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link:.
RBR50 - https://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.7.2.104.zip
RBS50 - https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.7.2.104.zip
IF this doesn't appear in the RBRs FW upate web page as being available, you can manually install and apply:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Update the RBS first, then RBR lastly.
Let us know how it works for you.
Good Luck.
  • Paul361's avatar
    Paul361
    Feb 03, 2021
    I became aware of the latest firmware while browsing this forum. Neither the app nor the web interface indicated an available update. I downloaded the files via my computer and performed a manual update via the web interface -- one satellite first, then the other, then on to the router. (RBK50) In the past, I have had updates pushed out (only once); notices both on the web and app of firmware updates available; and updates that I found were released via this forum which I've manually installed (the latter seems to be the most frequent way I have updated firmware). Through all ways, I have never had the slightest issue with downloading and installing updated firmware.
