Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.5.2.4 Officially Released
Bug Fixes: Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts. Fixes the system stability issues that occurred after the fi...
Mstrbig
Sep 17, 2020Master
I was asked to post this:
Just got off the phone with my NG rep. He said the ONLY official releases are located here:
https://www.netgear.com/support/download/
He said any other pushed releases may be a result of settings on the Orbi device, such as Armor, Disney, etc., and specific for that particular device, but not official for all devices.
He said he is aware of the download pages for newer firmware, but didn't comment further.
So the Netgear firmware version confusion continues.
- FURRYe38Sep 17, 2020Guru - Experienced User
Both versions appear when I input rbk50...
Also found here when you select DOWNLOADS:
RBK50
- MstrbigSep 18, 2020Master
FURRYe38 wrote:Both versions appear when I input rbk50...
RBK50
Netgear needs to get their act together with regard to their download website.
Both new versions of the firmware show up if you search RBK50 or RBK53, but not if you search RBR50 or RBS50, which is actually what the RBK50 and RBK53 systems are. Plus RBK50, RBK53, RBR50 RBS50 models in the V2 version, show 2.5.1.16 as the latest firmware.
Make it very confusing for the user, especially a novice.
- FURRYe38Sep 18, 2020Guru - Experienced User
Patience is key. :smileywink:
