Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.5.2.4 Officially Released
Bug Fixes: Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts. Fixes the system stability issues that occurred after the fi...
Raekon
Oct 25, 2020Tutor
Every time I see a new firmware update I download it, hoping to see improvements in stability and bugs compared to the last version, and every single time the situation seems to get worse! I can't remember a firmware update that clearly made my network much better since the very first ones I did years ago, it's actually quite upsetting that I had a much better product years ago when I bought it, despite the regular stream of updates. This particular new firmware makes your wifi go extremely slow and it's definitely the first time I considered downgrading because it was straight up unusable on all devices. However, looking at the logs I think I found at least part of the problem. I noticed my orbi was detecting a lot more DoS attacks and tried to block them. Pretty sure all of them were incorrectly detected because it was a constant stream of DoS attacks, much more than I've ever seen before on previous firmwares, even coming from the orbi IP itself! So I disabled the DoS protection and the wifi now is stable and working as intended. My guess is that there is something very wrong with the DoS protection and/or DMZ, it doesn't seem to work as smoothly as intended. Try this aswell if you notice your wifi becomes unusable.
thisoldhouse
Oct 25, 2020Aspirant
Where in the menu do find the option to disable DoS? I looked around in Advanced area but didn’t see it.
- thisoldhouseOct 25, 2020AspirantFound it under the logs. Well that worked perfectly!!!! All the issues are now gone and internet is back to normal. Netgear must not have a very good QA dept if they’re releasing firmware like this.
- RaekonOct 26, 2020Tutor
thisoldhouse wrote:
Found it under the logs. Well that worked perfectly!!!! All the issues are now gone and internet is back to normal. Netgear must not have a very good QA dept if they’re releasing firmware like this.The option to disable DoS protection and port scan is under Advanced -> Setup -> WAN setup and tick “Disable Port Scan and DoS protection”. I did this and it fixed most of the problem for me. Sometimes when I’m downloading and saturating my bandwidth my wifi still crashes for a little bit but in a normal scenario it works fine for now. Definitely not ideal but definitely usable.
If you just unticked “Known DoS attacks and port scans” under the logs page, then I don’t think you disabled the actual protection but just the logging of those attacks. Interesting that it works just as well as what I did though, I will try that aswell since having the protection active is better than nothing. Howerver it was blocking alleged dos attacks from Facebook IPs, basically anything it was blocking it shouldn’t really be blocked when I tried to lookup the IPs. It’s just doing a very poor job. As for Netgear’s QA department, I think the answer to your question is pretty obvious.
- thisoldhouseOct 26, 2020AspirantYep, I just unticked it under logging and it solved the issue. Maybe writing to the logs is the issue. Seems pretty odd that it would cause it but it resolved the issue immediately.
- FURRYe38Oct 25, 2020Guru - Experienced User
QoS on Orbi systems is automatic. There is no actual QOS user menu. Whats seen is a speed test app which when ran sets the auto QoS configuration to run with in those speed result parameters. It's all automatic. You can't disable it.
- thisoldhouseOct 25, 2020AspirantDoS not QoS. You turn it off in the logging and that fixed the issue. I saw the same constant barrage of DoS logs every minute.
Opps sorry that about that. Tired eyes. Glad you found DoS menu item.
