Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.5.2.4 Officially Released
Bug Fixes: Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts. Fixes the system stability issues that occurred after the fi...
Oct 25, 2020Guru - Experienced User
QoS on Orbi systems is automatic. There is no actual QOS user menu. Whats seen is a speed test app which when ran sets the auto QoS configuration to run with in those speed result parameters. It's all automatic. You can't disable it.
thisoldhouse
Oct 25, 2020Aspirant
DoS not QoS. You turn it off in the logging and that fixed the issue. I saw the same constant barrage of DoS logs every minute.
- FURRYe38Oct 25, 2020Guru - Experienced User
Opps sorry that about that. Tired eyes. Glad you found DoS menu item.
