Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.5.2.4 Officially Released
Bug Fixes: Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts. Fixes the system stability issues that occurred after the fi...
alokeprasad
Feb 23, 2021Mentor
Ha_Ku_Na wrote:
vajim wrote:
FURRYe38 wrote:Meaningless
This in NOT meaningless, this is a good reason to update the firmware, and there is another good reason to use an actual firmware:
https://kb.netgear.com/000062883/Security-Advisory-for-Multiple-Vulnerabilities-on-Some-Routers-Satellites-and-Extenders
Ha_Ku_Na,
Where/how did you find this web page? I need to add that to my "check regularly" list.
I normally check NG's security page https://www.netgear.com/about/security/
But this very recent info you posted (Feb 12, 2021) is not listed there.
Ha_Ku_Na
Feb 23, 2021Luminary
it is under "top Support Articles" here:
