Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Mstrbig
Sep 17, 2020Master
Interesting, it still does not show up here:
https://www.netgear.com/support/download/
I guess they haven't updated the site yet.
I have been running 2.7.0.70 since this past weekend, on 2 separate RBK50 systems. I've added up to 25 devices on both systems.
It is very stable and seems to give me faster network speeds. (examble, my S10+'s network speed was always around 585. Now it is constantly 700+. The WEB GUI and app and displaying everything correctly.
- FURRYe38Sep 17, 2020Guru - Experienced User
It shows for me while using rbk50...
- CrimpOnSep 17, 2020Guru - Experienced User
FURRYe38 wrote:It shows for me while using rbk50...
It does not appear on "Firmware Update" on my RBR50 running 2.5.1.16. Perhaps this is related to whether a person has "gone past" 2.5.1.16 at any point?
Setting my timer today to consider updating Nov 1.
- MstrbigSep 17, 2020Master
The 2.7.0.70 mystery continues:smileywink::smileylol:
It's rock solid here.
I just performed the textbook Netgear instructions for manual firmware update.
Satellites first, then router, then reboot. Only issue was I had to go to a few devices and forget the WIFI network and rejoin. In the app there were offline devices that were also showing online as well with a different MAC address. I deleted all the duplicate offline devices. The GUI never really had any issues.
