Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
chrisk1
Sep 18, 2020Aspirant
Definitley getting slower speeds with the update. May revert back.
Sep 18, 2020Guru - Experienced User
Did you activate any Armor or Circle?
Try a factory reset and setup from scratch if you didn't try this already and see if you speeds return.
What speed differences are you seeing? Wired and wireless?
chrisk1 wrote:Definitley getting slower speeds with the update. May revert back.
- chrisk1Sep 18, 2020Aspirant
Armor and Circle are not activated. I have only tried wireless and I'm getting around 300 when I should be getting 400. I was getting 400 without issue with the prior firmware. I also disabled the Daisychain Technology and turned on Beamforming.
