Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Kolja
Sep 18, 2020Initiate
After updating to this version manually I am not longer able to login to my router. It says the password is incorrect. It was not reset to the default 'password' either. I guess I have to proceed to resetting the device.
Sadly this experiece is on par with the overall software quality I expect from Netgear.
- chrisk1Sep 19, 2020AspirantSame exact thing happened to me. That’s what made me do the full reset.
- FURRYe38Sep 19, 2020Guru - Experienced User
Next time, try clearing all browser caches first before re-entering the RBRs web page. Try a different browser to compare.
chrisk1 wrote:
Same exact thing happened to me. That’s what made me do the full reset.- GMoGoody8Sep 19, 2020Luminary
Pulled the trigger and manually updated today. So far so good.
Kolja wrote:After updating to this version manually I am not longer able to login to my router. It says the password is incorrect. It was not reset to the default 'password' either. I guess I have to proceed to resetting the device.
