Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Supertramp11
Sep 19, 2020Luminary
RBR50 (Orbi Router) Firmware Version 2.7.0.70 (for US Region Only)
This restriction was added after I started using this version outside the US.
Although I believe it works fine, can I expect problems and would it be better to move to version 2.5.2.4?
Thanks for any advise.
