Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
chrisk1
Sep 19, 2020Aspirant
Same exact thing happened to me. That’s what made me do the full reset.
Sep 19, 2020Guru - Experienced User
Next time, try clearing all browser caches first before re-entering the RBRs web page. Try a different browser to compare.
- GMoGoody8Sep 19, 2020Luminary
Pulled the trigger and manually updated today. So far so good.
- FURRYe38Sep 19, 2020Guru - Experienced User
- GMoGoody8Sep 19, 2020LuminaryPW was all good. I did have one quirk that I typically reboot the Router and Satellites after both are upgraded fully. When both booted together the satellite received 192.168.1.250 and stayed there. Thought that was weird so I just reboot the Router again. Then everything was back to normal.
After all of that I tried the app and was immediately pushed the new IOS app with the new parental control settings with profiles.
I am also seeing some increased speeds on WiFi too. Though want to give it more soak time.
