Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
cookiekaikai
Sep 20, 2020Aspirant
Upgraded last week. I just found out the router doesn't show most of the devices in attached / connected devices in app or on the webpage. I thought this issue was resolved?
- GMoGoody8Sep 21, 2020Luminary
Looks Like the Site caught up. This FW is now listed for RBK50, RBR50, and RBS50 for people in the US.
- FURRYe38Sep 21, 2020Guru - Experienced User
How many devices do you actually have connected?
Are they all connected at the same time?
Might try a factory reset and setup from scratch.
Is RBS wired or wireless connected to the RBR?
Any Armor or Circle enabled?
cookiekaikai wrote:Upgraded last week. I just found out the router doesn't show most of the devices in attached / connected devices in app or on the webpage. I thought this issue was resolved?
- cookiekaikaiSep 21, 2020Aspirant
A reboot last night resolved the issue. I have 15-20 devices with circle enabled. I think there might be a small
FURRYe38 wrote:How many devices do you actually have connected?
bug. thanks- FURRYe38Sep 21, 2020Guru - Experienced User
Ok, good the reboot helped.
A full on reboot or power OFF for 1 minute then back on with the RBS and RBR is recommended first after doing a FW update.
Enjoy.
cookiekaikai wrote:A reboot last night resolved the issue. I have 15-20 devices with circle enabled. I think there might be a small
bug. thanks
