Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Sep 21, 2020Guru - Experienced User
How many devices do you actually have connected?
Are they all connected at the same time?
Might try a factory reset and setup from scratch.
Is RBS wired or wireless connected to the RBR?
Any Armor or Circle enabled?
cookiekaikai wrote:Upgraded last week. I just found out the router doesn't show most of the devices in attached / connected devices in app or on the webpage. I thought this issue was resolved?
cookiekaikai
Sep 21, 2020Aspirant
A reboot last night resolved the issue. I have 15-20 devices with circle enabled. I think there might be a small
FURRYe38 wrote:How many devices do you actually have connected?
bug. thanks
- FURRYe38Sep 21, 2020Guru - Experienced User
Ok, good the reboot helped.
A full on reboot or power OFF for 1 minute then back on with the RBS and RBR is recommended first after doing a FW update.
Enjoy.
cookiekaikai wrote:A reboot last night resolved the issue. I have 15-20 devices with circle enabled. I think there might be a small
bug. thanks
- MstrbigSep 21, 2020Master
Update:
Several days running 2 entirely different RBK50 systems on 2.7.0.70.
Everything is faster, both WIFI and wired. I forced several shutdowns and restarts and everything comes back up.
App and GUI are reporting correctly. It did take about 24 hours after reboot for things to settle down.
As far as I am concerned, this is one of the most stable firmwares. So stable, we have started updating our customer's Orbi systems, that support this firmware.
One thing, the Website show that 2.7.0.70 is for U.S. only.
For those reporting missing devices, or showing wired when wireless and reverse in app and GUI, a reboot of the router and satellites seems to correct it. For those reporting password reset, I'm going to go on a limb and say possible user error.
Best procedure to follow, when manually updating, is to use the Netgear instructions.
- CaplaurSep 22, 2020Aspirant
Did somebody notice, in Advanced setup/Wireless Settings, Transmit Power Control is now 25%, 50% and 100%. So, no more 75% option.
