Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
pengwn
Sep 25, 2020Tutor
Did this firmware remove the original Circle parental controls? I need to be able to limit access to sites per device and it appears that is now only available with a premium subscription. I used to do it before this upgrade, but I was one of the people experiencing the dreaded Wifi drops when Circle was enabled.
