Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
pengwn
Sep 25, 2020Tutor
Did this firmware remove the original Circle parental controls? I need to be able to limit access to sites per device and it appears that is now only available with a premium subscription. I used to do it before this upgrade, but I was one of the people experiencing the dreaded Wifi drops when Circle was enabled.
CrimpOn
Sep 26, 2020Guru - Experienced User
pengwn wrote:Did this firmware remove the original Circle parental controls?
Wouldn't it be wonderful if Netgear published a link to these new "Smart Parental Controls" so that customers could (for example) (a) see what they are getting into, or (b) compare Netgear's package with Disney's package?
Dream On. Looks like the only way to get information is to sign up and experience "whatever happens". Then, post on the community forum for Smart Parental Controls. Oh wait, there is not a forum for the new product.
