Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Oct 05, 2020Guru - Experienced User
FYI for users out side of the USA and Canada region wanting to use v70 FW:
- stewlevineOct 06, 2020Aspirant
So, my RBR50 and RBS50 finally pulled down firmware updates today (Oct 6), but pulled down 2.5.2.4, not 2.7.0.70. I am currently on 2.5.1.16 and am in the United States. Does this seem normal?
- FURRYe38Oct 06, 2020Guru - Experienced User
Yes. Not everyone may see v70. This one was directed towards a new kind of parental and Circle app controls. Users can apply this if you want too. However if you don't use Circle, I would probably avoid it.
stewlevine wrote:So, my RBR50 and RBS50 finally pulled down firmware updates today (Oct 6), but pulled down 2.5.2.4, not 2.7.0.70. I am currently on 2.5.1.16 and am in the United States. Does this seem normal?
- GMoGoody8Oct 06, 2020LuminaryYeah, I’m thinking I should have waited. I manually applied and don’t use either feature. I have a client stuck in the wrong profile because the default limit is 20 and I moved the wrong one.
Also don’t want to rock the boat loading a another firmware as everything else is great and have faster speeds from the previous fw.
- gr8shoOct 23, 2020Virtuoso
stewlevine wrote:Does this seem normal?
Based on what I'm seeing, yes. I've been at this with many users in this thread a long time. My RBK50 is seeing the same exact information as yours, and frankly I'm not going to bother with the latest 2.5 update. Eventually, NG will get around to offering 2.7. At that time, I'll apply the update in the prescribed order, and will do a factory reset. Fortunately my setup is rather simple so it won't be too difficult to get things back to normal .
- FURRYe38Oct 23, 2020Guru - Experienced User
FYI, I got word that NG is reviewing the problems found in both v4 and v70 versions of FW.
