Apr 11, 2022Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
Admin password brute force attack prevention
Admin password strength enforcement
EU data analytics opt-out
Bug Fixes:
The backup config file i...
Apr 29, 2022Guru - Experienced User
Eeeks, ya the RBS needs to be updated first.
Try this, Factory reset the RBS and don't sync it to the RBR. Have the FW 2.2.1.210 and v.24 downloaded on a wired PC. I think you may need to apply v210 first before v24.
Press the reset button on the back of the RBS for 15 seconds then release. Wait 5 minutes with the wired PC connected to the back. You should be able to use a web browser and navigate to 192.168.1.250 and use admin and PW. Should get you in to the RBS web page and update with the unpacked .zip file. I would use MS Edge or Firefox for this.
sjbayarea
Apr 29, 2022Aspirant
Thank you - I will give that a try.
I am almost at a loss as to how I even got here, as firmware (so I thought) gets automatically updated and therefore I am where I am. Devices that are closer to the satellite are not connected to it, rather to the router that is further away.
I appreciate the advice.
